CAT 6 Cable
rta53
Feb 2003
North Carolina
619
Doing my first job using ethernet I/P control with Control Logix and Flex I/O ethernet adapters. The spec requires CAT 6 cable. I wanted to buy good quality cable and it needs to be white. I tried to find Belden but having a hard time. Is this something I really need to be concerned about or does it matter as long as it conforms to the CAT 6 standard? One place I looked online had American made and imported cable. The imported was about $40 cheaper for 1000'. I've seen prices anywhere from $130 to $300 for 1000' of non-plenum cable.
Whose spec calls for CAT 6?
Why?
Nothing on an I/P network will make use of the small bit of bandwith available over CAT 5E.
Why?
The customer's User Requirement Spec is what I am having to conform to.
I agree that Cat 6 is going over board. Cat 5e is good for up to Gigabit Ethernet.
One detail that I always make sure of when using Ethernet in control cabinets is to use STP (shielded twisted pair) as opposed to the more common UTP.
Also be sure to use solid wire and connectors appropriate for it, it less prone to noise especially in longer runs. A good installer will avoid putting RJ45 plugs on cables themselves because it is not easy and possibly the most prone area for failure. A better method is to terminate to jacks and use pre-made patch cables to go from the jack to the device.
Greetings! I have an application where I am going to use IFM E12354 field wireable M12 D-Coded Ethernet connectors. (url below). I have...
1,183
Good Morning , I have a quick project to do , I know it is not a good practice , but can you put a shielded 120 ac cable in the same...
5,341
VFD Modbus RTU uses dual RJ-45 connectors for easy daisy chaining devices in an RS-485 network. What do I need to spec for shielded CAT X cable...
1,641
Can you please provide the pin-out diagram for following; which is used for Debugging of Prosoft make Modbus EtherNet TCP/IP module cat...
2,546
Here's the application: I'm have Panelview 600 with two 485 ports I'm moving. On the Panelview there's a big connector like what's on the PIC...
4,658
