Cavana flow wrapper
aand74
Dec 2005
Deinze
131
Has anybody experience with a Cavana Flow wrapper machine that was build about in 1997?
Our customer has one.
I has a Siemens S5 plc, a drive system from Infranor and a pc based motion controller.
Has anyone information about that pc based motion controller?
What software can I use to open the source files of the pc system?
Do you think there are source code files on the PC? If so, what are the file extensions?
All the software in the world won't open the source files if there are not any on the PC.
It is not a tradional pc, but somekind of motion controller based on a 486 Intel CPU. There is no keybord or monitor.
I received two files that I suppose are from this system :
CVMOTION.MES and CVMOTION.PAG.
It would help me a lot if I had the software that can open these files, so I would see the motion configuration.
Have you tried opening the files with something like Notepad++ ?
It might give you a clue what software is required - it's a long shot I know, but might be worth trying.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
193
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
170
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
67
I can't seem to figure out how to add descriptors to I/O points on an RMC using PCCU. Say, for example, I want to use "Valve_1" as a descriptor...
81
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
151
