Change Counter Acc in Code RsLogix
BigJohnT
Apr 2006
Poplar Bluff
18
Can you change the value of a counter Acc in code with RsLogix on a 1500 micro?
I have some sequence logic that uses a counter to control the sequence. In some cases I need to back up the counter.
John
John
yes, a move instruction will work. MOV n7:0 c5:0.acc
Also SUB, ADD, DIV, or MUL.
BigJohnT said:
Thanks, I did not even think about the math instructions (slapping forhead)
John
I belive the CPU will fault if the counter/timer accumulator gets a negative number in it though. Some range checking would not be a bad idea.
That's for sure something like -32647 to 32648 or some number like that will fault the cpu.
THanks
John
The PLC will fault on negative numbers for timers. However counters do just fine with negative numbers in the PRE and ACC.
264
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
130
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
272
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
93
We had one go down. we have a new one. Their emergency Number don't work. The Model is TLSA046AAH-330N01-007 A catalog says we need software TET...
183
