Change Over Communication
gherz817
Oct 2005
PHILIPPINES
58
Is there a posibility to configure two communication in citect scada? I will add a button to change over the communication, either via a serial to LAN or vise versa.
Thanks..
Thanks..
i'm so happy, in this forum many people use citect scada, i 'm a newbie in that scada.my problem is, the citect no always run much better, not always connect the communication, why is that can happen ?
Thank you
Adi P.Nugroho
SWCU-Indonesia
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,316
We have Panelview 600 "Standard" on one of our machines which we got from supplier. We don't have documentation or software to upload/edit file...
3,725
Witam! I configureted Simtatic Stations Master CPU 315-2 DP and Slave CP 342-5 according to Simens' example...
1,820
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
222
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
110
