Change RACK ID on Kepware dynamically !!
amitgolwala
Jun 2011
Singapore
Hi all,
I have written this OPC driver that talks to the Kepware OPC Server using j-interop library. The Kepware OPC server is configured to read from and write to Siemens S700 PLC. The Siemens PLC are redundant i.e. if one fails, the other takes over and is seamless to the Kepware OPC server.
However, there is an issue with the RACK ID parameter of Kepware. My Kepware OPC server configuration points to let's say IP - 1.1.1.1, RACK ID 0 (default). Now if the active Siemens PLC fails, the standby takes over and dynamically changes its own IP to 1.1.1.1 but it cannot change its RACK ID to 0 as 2 Siemens PLC cannot have same RACK ID.
So, one of the solution is to dynamically change the RACK ID on Kepware, but I am not sure how can that be done from my driver - any clues? :(
Thanks in advance !!
Amit !!
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
219
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
110
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
224
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
83
We had one go down. we have a new one. Their emergency Number don't work. The Model is TLSA046AAH-330N01-007 A catalog says we need software TET...
176
