Changing bit in STEP 7 with some frequency
Adenitz
Feb 2010
tir
41
Hello all,
I have one step 7 simatic program in which I noticed that one bit is constantly changing every two sec, but I cannot find any timers in the program.
How is that made? Can you give me some guidelines?
Thank you L D[AR2,P#0.0], I have set this byte MB 0.
Now I can see that all bits M0.0 to M0.7 blinking at different frquency.
I'm pretty much sure about M0.7. It is blinking in such way that 1 is present for 1 sec and pause is also 1 sec,so overall period is 2 sec.
How to determine the rate blinking of other (faster) bits?
Look at help, it gives all of bits blink rates, they are always same amount off and on. Mx.0 = 100ms, Mx.1 = 200ms. Rest look at help.
can you please email me the program or guide me step by step,
i need to toggle a bit in 100Hz frequency
how could i ?
thanks
Hi, I am using the DN bit to stop the timer. However the DN bit doesnt change state. Please see the attached image. Any help is appreciated.
2,831
Hi, I am creating a HMI project that is using kepware OPC server to communicate with a square D PLC. I need to create something like a...
1,925
Hi Just have a quick question, I am updating HW config of a system which uses a few DI / RO and AI inside with an ET200S. Card one uses byte...
3,338
Hi How can I set a value(like something in MW0) with both PLC and HMI?
2,195
How can I program this: I have 16 alarms in a word. When a there is an alarm, I want to detect this, so I compare it with zero. When there is a...
44
7,296
