Character - lower case to upper case, SCL? or STL?
rpop91
Mar 2012
Detroit, Mi
44
Hey guys,
Back again. I'm having trouble finding a simple way to convert each character in an array from lower case to upper-case.
I can't seem to find a simple solution. Would it be a good idea to write this in SCL or is there a SFB or something I don't know about?
Any help would be greatly appreciated.
Thanks!
Hey guys,
Thanks!
Generally one would subtract 32 Dec. from the lower case character's value to get the Upper Case character equivalent.
Here's upper to lower...
Code:
FUNCTION fc112:VOID
VAR_in_out
   ac:ARRAY[1..100] OF CHAR;
END_VAR
VAR_temp
i:INT;
x:INT;
ct AT x:ARRAY[1..2] OF CHAR;
END_VAR
BEGIN
x:=0;
FOR i:=1 TO 100 DO
ct[2]:=ac[i];
IF(x>=65 and x<=90) THEN
 x:=x+32;
 ac[i]:=ct[2];
END_IF;
END_FOR;
END_FUNCTION;
Code:
FUNCTION fc112:VOID
VAR_in_out
END_VAR
VAR_temp
i:INT;
x:INT;
END_VAR
BEGIN
x:=0;
FOR i:=1 TO 100 DO
ct[2]:=ac[i];
 x:=x+32;
 ac[i]:=ct[2];
END_IF;
END_FOR;
END_FUNCTION;
Thanks a lot, changed a few things in that code and worked perfectly.
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
450
This may or may not be the right fit for this forum, but I'm hoping someone can recognize my issue and help me sort this out. I'm working to...
2,177
This is for editing HMI texts en masse in Excel. My problem is that in my HMI texts, some are in multiple lines, even if they are single texts...
26
9,220
Hi. I migrated panelbuilder32 hmi to factorytalk view. However character array is not supported in ftview. Appreciate your help how to map the plc...
1,763
Hi All, have a quick one new enough to this type of programming, I am using a Allen Bradley point IO with 1734-232ASC card to send out data, I...
2,613
