cheap plc
guest uk
Guest
G
Just a little advice needed about which is the beast and cheapest PLC to
buy in order to learn Ladder Programming at home???
Thanks.
Dont need to buy one at all really. Goto www.learningpit.com and get Logixpro. It can simulate the programs you write. It also provides projects to learn from.
www.ebay.com has most major brands that can be obtained cheap.
www.automationdirect.com has reasonably priced products.
www.ab.com/micrologix has a $100 plc with a free version of RSLogix500
www.entertron.com has reasonably price plc with free software.
I dont have a link but Siemens offers the S7-200 (starter kit)with software, cable etc at a reasonable price.
Try to obtain a plc that is dominant in your area/country.
Also, try unitronics. At $250, the M90 also has a built-in 1-line display and keypad, so you can get practice with messages and operator controls.
Since each key on the pad can be assigned anywhere in the program as a contact, you can use it to simulate physical inputs. Press 1 to start a timer, press 2 to make a "Limit Switch" or allow time to run out and display a fault message.
Or reverse it. Try giving each button on the keypad a different function depending on what the display shows. Now, you have menu options.
Lastly, software is free, and it's not limited at all, the full version. More information, and download the softs, at www.unitronics.com
When you're ready, we can talk Canbus, Modbus, RS485 networking, 4" and 5" LCD touchscreens, ethernet...
TM
105
Cheap PLC that can read Data from its SD card or USB Flash Drive? I'm looking for something in the price range of a Productivity 1000 ($180 for...
4,645
Hi, I am working on a little project and looking to either buy a Siemens S7-1200 or an AB Micrologix. Does anyone on here have a spare they want...
1,789
I have a bucket load of experience with GE PLCs but almost zero experience with Rockwell PLCs - which is pretty well the opposite of the market...
3,763
I'm one to grab hold of a gift horse's mouth, shine a torch down it's throat and have a bloody good look... I've only really used A-B...
3,487
