chemical batch control-idec FA3S-CP12
chris clayton
Nov 2002
I'm ha student having trouble with program; using an IDEC FA-3S CP12
3 addditives mixed of = proportions thru mixing manifold which has a flow meter of 100 pulses per litre of flow,additives controlled by valves V1 V2 & V3.time delay of 5 sec between additives.batch is continuously stirred by motor M1 while being mixed.Then batch is heated by heater H1 to between 60c-65c & stirred for 15min when batch reaches 60c.Batch then allowed to cool to 30c at this point stirrer stops.Batch is then emptied via valve V4 & a pump M2,V4 cloes & M2 stop when tank is empty,this is indicated by level switch LS1.
Batch quantity is entered by 2 digital switches with a range of 20 litres to 90 litres.If batch quantity entered is too low an alarm (Q20) is activated & process is stopped.If quantity entered is too high an alarm (Q21) is activated & process is stopped.
Process is started by a single start switch & new data is not to take effect until previuos batch is complete.
Temperature of batch is monitored by a transducer & amplifier that provides an output of 1.0v\c unit is calibrated for 0c to 100c,providing an output of 0 to 10volts.
A level switch (LS2) is to monitor the level in the tank,if this ries above the maximum the switch should open & cause the disconnection of valves V1 V2 & V3 & raise an alarm (Q30).
at 30c stirrer stops.
Looks to me like you are trying to provide an output up to 100Volts.
Seems like it should be something closer to 1.0V/10-Degrees C.
If the Temperature Calibration issue is not the problem... then what is your question?
Can anyone help me with this project(chemical dosing pump) using logo siemens software: When you press the start push button, it should actuate a...
59
6,519
Very interesting read and every WTP staffs nightmare. No one ever wants to end up on national news. Instrumentation work distracts staff and...
5,686
Hello, I am relatively new to PLC's and water treatment. I currently working in a water treatment facility as an instrumentation worker. I have...
2,099
We have a wash facility which uses a venturi to draw an iron phosphate chemical from a tank into a high pressure water line running at 160 bar...
1,755
Hi all, I have a horizontal chemical chamber(cylindrical) of length L and diameter D and radius R(D/2). I need to monitor volume of chemical...
3,024
