christmas lights
Hmm, I read a couple of the comments on that video. One person said something along the lines of "I think that guy got offered a job by NASA".
I doubt being able to program a sequence of lights qualifies you for NASA. Most Automation students do that by their first year :).
Using a plc on Christmas lights is pretty expensive but if you have some lying around like I did then it is okay. Just use standard ladder functions contacts and output coils, internal relays etc. be careful of the type of enclosure that use use. It needs to be rated for the environment you will be placing the equipment. I use sequencers to make some reindeer walk around the trees 4 or 5 of the lighted reindeer around a tree and fire them one after another with the sequencer or standard timers the a pause in one position and start over again just run it on a loop. I have a lot of the outdoor inflatable’s that I separated the light circuit from the motor circuit so I can turn the lights on and off to music or a speech story but the units stay inflated. I have several supply circuits running through contactors that I start at 6:00 pm and end at 11:30 or so. Turn these on with timed delay between each to minimize inrush current you can use the plc’s internal clock for this. I am using a plc 5 and some micrologix plc’s .best to use triac outputs as you will wear out relay outputs fast like this and you have timing issues sometimes when using relays depending on the effect you are trying to create . I have a Linksys wireless access point connecting the plc to the house if I want to make changes. I normally add something each year. Just start small and have fun. PM me if I can be of more help
DIY Xmas
I believe this is the kind of stuff most DIYers use to do that:
http://www.doityourselfchristmas.com/
They have a beginners forum:
http://www.doityourselfchristmas.com/forums/showthread.php?t=3818
And a getting started guide:
http://www.christmasinshirley.com/wiki/index.php?title=Beginners_Guide
It shouldn't be too awfully different than programming a PLC but you have to have a dedicated computer to run the program and an FM transmitter so passersby can pick up your music.
Cool stuff if you have a few hours to kill.
Archon
Any older members will remember I posted that very same link 3 years ago.
It isnt done with a plc but a sound to light unit
Click on this link that will take you to a youtube video, It shows you a light show
that is synchronized to the music than it replays the music while you watch all of the PLC’s outputs that control the lights fire up. I’m not saying that you are wrong about the sound to light unit. But this guy has clearly used a PLC.
http://www.youtube.com/watch?v=rz8XnWeK1N8
sparks32, how are you planning on syncing music with the plc?? How are you going to fade lights, cheaply with a PLC?? It is possible, but just plain silly when you can buy stuff way cheaper in comparison to a PLC, and it is a snap to program.
It's that time of year: how are you using PLCs to run your lights or animated displays?
3,048
Hi all, I'm new to forums and plcs and I am self teaching with internet info and trial and error. I will be getting a click plc with analog in...
4,096
You guys have to check this site out. http://www.collegehumor.com/movies/1634181/ Talk about an amazing, coordinated light display. I...
3,498
Every one of us has thought about animating our christmas lights. Many might have done it to a degree, but I bet no one has done it like this...
29
13,109
D
Hi Can someone please tell me how to write a RSLogix 500 PLC program that will decrement and increment or use a bit shift that will allow the...
15,597
