Cimplcity runtime license
sultanahmed
Jul 2013
home
63
Hi All,
I am using cimplicty in which i have 2400 I/o's discrete input(1200) discrete Output(1200) 24vdc.
i will use some memory addresses in cimplicty around 300 points.
Question is how much runtime system Cimplictity I/o points license required.
Similary i am using Machine edition software.
how much runtime system Machine Edition I/o points license required.
šŸ™ƒ
More information will be needed to give you accurate information.
For Cimplicity HMI/SCADA you need only count the hardware points accessed from the controller(s) so a 300 point runtime is likely all you need unless spares are required. Total the In's, Out's and internal Addresses (Variables) accessed from all controllers, do not count internal variables used only by the runtime.
For Proficy Machine Edition (Cimplicity Machine Edition is obsolete.) you only need to count points for its "PC View" module, which is similar to but not the same as Cimplicity HMI/SCADA. But points are counted the same, only hardware points directly accessed by the runtime.
Hi, I am using Cimplcity Version 7.0 my Dongle Usb was defected i purchase new dongle for it,New Dongle Usb is Version 8.1,error occur, error is...
1,226
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
70
when i tried to go online, why its showing lie this
98
I have been trying to add a button to an HMI Panelview version 5.1 for a couple days. Each time I download I get no data in my buttons, only...
215
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
720
