Cimplicity Tag export
jed
Jul 2006
Leeds
22
We have copied the project folder from one machine to another but it will not run and gives errors. So we need to at least export the tag database from one machine to the other, does anyone know how to do this?
We are running a very old version but not sure which it is.
Look in your help file for the "clie" command. Then it should list items for import and export.
Before you do that, what errors do you have? It may be easier to fix than exporting and importing tags.
Cimplicity Tag Export
Not sure what errors there were, will have to contact the guy on site to confirm. Thanks for your reply.
Point import and export are performed using the commands:
clie import <filename>.csv
clie export <filename>.csv
These are the basic commands. See chapter 26 of the “Cimplicity Base System: User’s Manual” (GE Manual number: GFK1180G) for information on command line switches and other options.
I have a question related to the tag definition of a Cimplicity HMI tag. I have an existing application in which I have csv export of the tag DB...
2,062
Hi Everybody, Is is possible to write an application which can be called from the Cimplicity HMI, to show an overview of all points...
2,234
Hi there, Situation: We've got several structured tags in a WinCC application. Those contain integer values which in turn contain bits that...
5,641
Hello, I am working with cimplicity workbench, I have made changes to the current project from this machine I am using in the past. However when...
65
I am currently working on a project involving Cimplicity 10, which consists of a setup with two redundant servers and five operator workstations...
56
