CIP Messaging/ and or options
inkman2004
Apr 2016
texas
I am trying to send a message between a micro820 and a micro850. It is basically a plant shutdown bit. I have a PV800 in between the two. Is there a way to retrieve the bit from the HMI since i am having problems getting the messaging to work between the two plc's. I have tried tech support but all they do is point me in the direction of tech pubs which I had already been looking at.
Welcome to the Forum !
I'm not at all comfortable endorsing communications messaging between two micro PLCs as a "plant shutdown" feature. I strongly recommend you review the regulatory environment and hazard analysis before implementing a tenuous networking link for a critical process function.
That being said, I presume the two controllers are both on an Ethernet network ?
Go ahead and point to the same technotes that you've been reading and see if you can figure out a specific element of those technotes to narrow down your question. Otherwise we're just guessing about what you've read and what you've tried, and starting from scratch.
Hi, First time poster, long time reader. I've got a mass flow controller device for controlling the flow of gas. It has a flowmeter and an...
292
I noticed something that’s mostly just a curiosity. Maybe someone here knows. An IT system is reading a L82 with the on-board IP and 1,0 added...
708
I don't have much experience with Rockwell CIP messaging so hoping for some help. Wondering if anyone has dealt with sending the messages...
757
I can't seem to get messaging to work between L84E CLX processor and a PLC5/40E processor.What would the path be? Currently I have: processor,2,IP...
1,226
Background: Micro850 Controller and using generic CIP messaging to a Powerflex70 VFD via a 20-COMM-E ethernet adapter. Could someone help with...
1,117
