Citect 7.2 Server Behaviour
Jul 2007
Kiruna
600
After 2 days of stressful playing with a citect application (V7.1) trying to find out why events where not firing, cicode executing when commented out I found out why....
Been a server application all the clients had to be shut down. The clients cicode was executing even thought i removed it from server and causing problems.
Does this mean every change I make to the server application I have to shut every client in the plant down?
Every small change I make to a graphic I must compile the application and restart? Surely this cannot be the case?
I am running v7.30 SP1 and remembered that Citect made some changes around v7.20 that helped me a lot with not needing to restart clients after a new server compile. For some things (adding tags for example) the client still needs to be restarted (shut down Citect and restart the app, not reboot machine). ....
I think graphics changes in 7.20 simply require a compile, and then refresh the page on the client machine.
To remotely restart Citect on a workstation, see Q6089 "Using Shutdown() cicode function to shut down the remote SCADA machine"
That might help if you have a bunch of spread out workstations, you could remotely shut down Citect on them (from a central workstation) and if you have auto-login and Citect in the Startup list, it should come back to Citect runtime application.
I know this really doesn't help you now at version 7.10, but 7.20 did make my job easier...
Looking for some help with the connection issue between Citect 2018 and Top Server v6 for Opto22. I’m setting all this up to communicate with some...
128
Hi Friends, I have a Vijeocitect SCADA system with One Primary Server, One Secondary, and Two Client Severs, all running on Windows XP Pro...
2,086
Hi Friends, I have a Vijeo Citect SCADA Redundancy issue and I believe some Friends here might have had the experience before now. I will be...
2,335
Hi Friends, I'm working on a Redundancy discrepancy on our VijeoCitect SCADA, The Primary can not take over when the Secondary Server goes down...
1,296
Hello Everyone, This is my first time posting here so I hope y’all can help me. I am an IT Specialist with a company that has very old equipment...
5,286
