Citect Alarm Areas
zankorel
Dec 2008
Hunter Valley
173
I am trying to set up a simple 2 area system for alarms in Citect.
What i want to happen is that only User 1 can view Area 1 alarms. User 2 can only view Area 2 alarms. Each user cannot see the other areas alarms.
Logically, and from the help files, all i should have to do is give Area 1 alarms and Area of '1' in the Digital Alarms window, and give User 1 a Viewable Area of 1 in the Users window. Likewise with Area 2 and User 2.
What actually happens is that both User 1 and 2 can view Area 1 and 2 alarms.
This should be simple! What am I doing wrong? Argh!
[edit] I have also tried experimenting with assigning priviledges, but to no avail.
This should work. But assining privileges and areas to a user can be a little confusing. check if the users have acess to their relevant areas.
regards,
Marsupilami
regards,
Marsupilami
I agree, in fact i know it works because i managed to assign an area to an alarm the other day by mistake and wondered why i couldnt see it until i logged on as my default user then it appeared.
After further testing, it looks like setting a global privilege gives access to all areas, and overrides the viewable areas setting.
Just one of those Citect quirks, I guess.
Hello, First of all, I hope everyone is doing ok. I need to create a custom alarm and summary page in a citect scada project. I wanna utilise the...
1,149
Hello. I am using vijeo citect 7.40, I want to acknowledge alarms through a physical push button. Can anyone help me regarding this
2,641
i have a problem with vijeo citect 7.2 alar, server stopped and not shown the alarms when i a in run time mode . what i can doooo to restart alarm...
1,973
Hello all, I'd like some advice on how to write the unacknowledged alarm count from Citect 2015 into a ControlLogix PLC. Cicode is relatively...
2,291
Hello, I have configure some digital alarm and thats alarm i have to Log in SQL using cicode but when i am trying to this this it cant work...
2,551
