Citect Cicode symbol animation
dmned64
Jun 2013
Florida
99
I am thinking through a Cicode function or task that will do the following:
- monitor the status of bit1 and bit2
- if bit1 is 1 and bit2 is 0 animate a symbol at ANx to flash yellow
- if bit1 is 1 and bit2 is 1 have the same symbol display solid green
- if bit1 is 0 and bit2 is 0 have the same display display solid grey
bit2 would never equal 1 unless bit1 is also 1.
I am trying to write a Cicode function or task using DspSym and DspSymAnm but not having much success. I am not sure where the Cicode should reside and how it should be called. Is it in a Cicode file or a Cicode object on the graphics page?
With a little perseverance I figured it out. I have a Cicode object on my page that calls and passes arguments to a custom function I wrote to perform the animation. It's doing exactly what I wanted.
Another method would be to use a multistate Symbol set or array symbol set - I have assumed Bit1 and Bit2 are Variable tags
I looked at, and have used, multistate animation but I couldn't imagine how to make one of the states blink or flash and have the other states have non-flashing symbols.
I have a similar application where symbol color needs to be steady for some states and flashing for other states. Any solutions please dmned64?
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
295
Hi guys, its my first time progamming cicode and I need to do popups alarms, there are several digital alarms and in their rising edge transition...
512
Is there a way to run a Cicode function in the Cicode Editor? I have a function that works but I would like to run it without having a button on...
2,992
in the past i have only been doing small mods to existing cicode and coping sections to reuse and modify to suit. Now i have been tasked to write...
2,792
Does anyone have a Citect 2018 CiCode Reference Guide in pdf Format??? I know all the functions are in the help but..... I like to print them out...
2,237
