Dear All,
What’s is the main cause of this error on the Citect Screenshot which I cannot figure it out even though I set the parameters already all correct , did I miss out something ? Can you please help me ? Database can be connected but this issue is I can’t seem to quite get it , moreover i'm using 3 plc linking to a router switch and linking up with my Laptop. Hope you intelligent ppls can help me
My Router LAN Default Address is 192.168.250.1 Subnet Mask is 255.255.255.0
Then my laptop is 192.168.250.2 Subnet Mask is 255.255.255.0
I/O Devices
Name: IODev_M1006 Number: 1
Address: 0/6/0/S
Protocol: OMFINS3 Port Name: PORT1_BOARD1
Name: IODev_M1007 Number: 2
Address: 0/7/0/S
Protocol: OMFINS3 Port Name: PORT2_BOARD1
Name: IODev_M1007 Number: 3
Address: 0/9/0/S
Protocol: OMFINS3 Port Name: PORT3_BOARD1
Server Name: IO
Name: DISK_PLC Number: 4
Address:
Protocol: GENERIC
Startup Mode:
Memory: TRUE
Server Name: IO
Name: IODev Number: 5
Address:
Protocol: OMFINS3 Port Name: PORT4_BOARD1
Ports
Server Name: IO
Port Name: PORT1_BOARD1 Port Number: 1
Board Name: BOARD1
Special Opt: -I192.168.250.6 –P9600 –U
Server Name: IO
Port Name: PORT2_BOARD1 Port Number: 2
Board Name: BOARD1
Special Opt: -I192.168.250.7 –P9601 -U
Server Name: IO
Port Name: PORT3_BOARD1 Port Number: 3
Board Name: BOARD1
Special Opt: -I192.168.250.9 –P9602 -U
Server Name: IO
Port Name: PORT4_BOARD1 Port Number: 4
Board Name: BOARD1
Special Opt: -I192.168.250.1 –P9600 -T
Best Regards
Sebastian Tay
I/O Devices
Address: 0/6/0/S
Address: 0/7/0/S
Address: 0/9/0/S
Server Name: IO
Address:
Protocol: GENERIC
Startup Mode:
Memory: TRUE
Server Name: IO
Address:
Ports
Server Name: IO
Board Name: BOARD1
Server Name: IO
Board Name: BOARD1
Server Name: IO
Board Name: BOARD1
Server Name: IO
Board Name: BOARD1
Best Regards
Sebastian Tay
