citect scada and sql
salamplc
Jan 2019
ir
hi.
I want to connect to sql server and i get data from it and i show it on textbox in citect scada 2018.i have this code for this task.data does not show on textbox.please say your idea for me.
INT
FUNCTION
GetNames()
INT hSQL;
STRING sName;
INT Status;
hSQL = SQLConnect( "DSN=impaytere_ss" );
IF hSQL <> -1 THEN
Status = SQLExec( hSQL,"SELECT CNAME FROM FETISH WHERE SURNAME = 'Jumpy' " );
IF Status = 0 THEN
WHILE SQLNext( hSQL ) = 0 DO
sName = SQLGetField( hSQL, "CNAME" );
// whatever you wish to do with this data...
END;
SQLEnd( hSQL );
ELSE
Message( "Error", SQLErrMsg(), 48 );
END;
ELSE
END;
RETURN sName
SQLDisconnect( hSQL );
END
Where are you trying to execute the GetNames function?
You did INT function, which expects to return an integer, not a string.
hi
thank you for your answer
i made a textbox object in citect graphic builder and i opened textbox properties window."sName" variable put in "string expression" part in "appearance" tab in textbox properties.also GetNames function put in "up command" part in "input" tab in textbox properties.
i delete int in first code line but i con not see database value in text box.
when i run my citect project ,i show a empty textbox .when cursor is put on textbox,i show "good" notification on textbox
SQL Exec is to run a stored procedure if that procedure does not exist it will not work.
I suggest you iterate through the data & compare
or use the select
SELECT Name
FROM Customer
WHERE Name = 'John'
However this may return more than one unless the Name is unique.
Also your while next statement may move the pointer to the next field
or use the select
SELECT Name
FROM Customer
WHERE Name = 'John'
hi
thank you for your reply .
i used "select" in my code.there are data in table according to select function.i sent my table by attachment.
I have never used that SCADA so do not know the SQL Functions
This is what I did as a quick check in another Scada but totally in Basic
Dim Rs1 As New ADODB.Recordset
Dim Conn1 As New ADODB.Connection
Dim SQLStr, First_Name As String
Sub Main()
Conn1.ConnectionString = "dsn=Names;uid='sa';pwd='';"
SQLStr = "SELECT CNAME FROM FETISH WHERE SURNAME = 'Jumpy'"
Conn1.Open
Rs1.Open SQLStr,Conn1,,,
First_Name = Rs1.Fields(0).Value
Rs1.Close
Set Rs1 = Nothing
Conn1.Close
Set Conn1 = Nothing
End Sub
I created your Database and then run this script and it returned "Jill" in my variable First_Name however I did not include any error checking
Sub Main()
Conn1.Open
Rs1.Close
Set Rs1 = Nothing
Conn1.Close
Set Conn1 = Nothing
End Sub
hi
how to configure database to connect citect scada by ado.net?
The SQL commands native to Citect work fine. I wouldn't bother trying to figure out how to get ADO.Net to interface to the database.
hi
Thank you for your reply
I would like to use ado.net but i do not know about configuring it.do you have any document for it?.
You need to change the SQLExec to this I think
SQLExec(hSQL, "SELECT * FROM FETISH WHERE SURNAME = 'Jumpy'");
If SQLNext(hSQL) = 0 Then
END
hi. I want to connect to sql server and i get data from it and i show it on textbox in citect scada 2018.i have this code for this task.data...
1,622
Hello all! I am new in Citect SCADA. I need to create material tracking system in which I have a dozen of photometric sensors. When each sensor...
3,019
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
111
138
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
366
