Citect SCADA - Supergenie ?#? Any Limitation?
What version of Citect?
I ask because if it is 7.2 then you don't need to use numbers you can use text eg ?running? Makes it all a lot easier to read
Not sure what the limit is, but if you use the A s s function you can keep adding more, Ive got to about 40 with no problems
I remember that some where in the documentation it mentions that we can pass up to 255 parameters to a supergenie pop up page. If you are using A s s w i n function, maximum eight parameters only can be passed. if you want to pass more than 8, use A s s function to associate variables one by one and then call A s s p o p u p function
Mind telling more of ?running?
I'm currently using ver7.0 on project purpose.
We have the ver7.2
Thanks, now I remember I read stuffs like that, 255 parameters.
I've found out about the adding stuffs, but it's kinda troublesome I thought, to individually assign up to a huge number of parameters as of the original 8.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
66
73
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
330
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
414
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
289
