Citect SCADA with Rockwell ALMD Instructions
Ian S
Apr 2004
Sheffield
50
Is it possible to use Rockwell ALMD instructions with Citect SCADA 7.2?
Obviously, I could simply tag up to the .InAlarm bits, but this renders the use of ALMD fairly pointless. I was wondering if it is possible to to get Citect simply to subscribe to the CompactLogix for Alarms and Events, as one would with FactoryTalk View SE.
Cheers,
Ian
That is rather unfortunate, but understandable to get people to buy their equipment. Thanks for the info
It's a shame, because I find the ALMD and ALMA instructions very useful, but mainly only when I've got an FTView SE SCADA.
Even without View SE though, I like them, because they have all the timeout, deadband, acknowledgement and disable functionality built in. If I've got just a PanelView or another SCADA attached, I can still use them by mapping to these bits in the traditional manner.
The downside is that they take up about 1k memory each when you're only using a fraction of the full functionality. However, if program size is not an issue, then it saves you the trouble of "rolling your own".
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
48
70
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
328
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
403
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
287
