Citect Scada
Hellop;
SFC (also known as GRAFCET) is a design tool for automation control (it can be used to organize Ladder logic, or it can be used as a programming tool).
Break down your process in distinct and logically seperate steps (actions). Determine the logic that will enable each step at its own time (transitions). Setup a structure that will allow logic to flow from one step to another according to strict rules of evolution (only one transition valid in a sequence at any one time; only one step active, , unless the evolution requires parallel processing of logic [AND evolution]; etc...)
It is a very powerfull tool for sequential process design (conveyor lines, packaging lines, etc...)
The following diagram is extracted from a process we are controlling in PCS7, with the SFC editor.
Hope this helps,
Daniel Chartier
Apologies. I misunderstood and thought the question related to the language used to write Citect.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
50
70
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
328
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
403
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
287
