CITECT - Select Tags at Runtime
Jun 2007
uk
1,538
Hey, does anybody know of a function within Citect where at runtime you can have a user select a Tag from the database ?
Essentially what i need to do is let the user select multiple tags and then somehow add these together to display a total based on the tags selected ?
I know it sounds simple but its proving to be a little tricky, any ideas would be great
There is a cicode function to allow a user to select a tag. Not sure what it is at the moment, if no-one else comes in with the answer, I will tomorrow. Or you could do a search on the help, I think it is under miscellaneous functions
Cheers, unless i am being incredibly dumb i cant find any reference to the function, if you can remember it that would be great
The function you're looking for is called TagDebug. I don't know if you can use it in runtime. I believe you've got to have access to the kernel function to use it.
Kind regards,
Thanks, i know about tag debug but that is what it says, a tag debugging tool, it does not allow me to pass the value onto a runtime screen
With TagDebug you can both read from and write to any configured variable tag. Looking at the online help, it seems you don't need Kernel functionality to use it, contrary to what I've said before.
Kind regards,
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
46
68
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
100
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
78
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
84
