Citect - Twido - Modbus RTU
cobracat
Dec 2013
Palembang
Hi, I want to ask something
I have a Vijeo Citect V7.30 SP1 and Twido TWDLMDA20DTK communication with MODBUS RTU RS485. Honestly I'm beginner with citect, this is my first time. So I doing this.
-I make a project, filled cluster, alarm, etc like tutorial said.
-use express wizard->choosing twido->modbus/rtu->address 1->finish
-Variable tag->int or digital->address with 40001 or 00001->scale 0 to 100->done
-computer setup wizard->follow the instruction->finish
-then make simple graphic builder start-stop and 1 ligth
-compile with no error then run, nothing wrong
-but when I clicked start button that in runtime, nothing happen. even the light I made didnt change color at all
-and when I see my PLC, it looks like didnt running too
so, did I miss something? or my communication failed?
sorry for my bad english, I try my best to make it understanding
Did you set the twido modbus parameters as a slave??
All other parameters must be unic in citect and twido. 8N1 is the best. Also check the com port. Did you set it right in communication wizard???
If your connection was not right you will see the citect icons with dot's on them.
Thanks for ur reply. I'm using tsxcusb485 that didnt have master/slave trigger.
But now I found out that I could communicate it via opc KepServerEX.v5. Make it simple but just demo version, will expire every 2 hour connecting. So now I'm trying to connect it directly from citect to twido and get nothing. Twido didnt respon anything from citect. So my question is, did I need to add modbus parameter to citect.ini? What kind of paramater did I need generaly to add? InitType or something else?
Hi Everyone...!!!! I have configured my IP address and also created a server in Citect of that IP address.I have also mapped my I/O's to Modbus...
2,875
Hello EveryOne...!!! Please Let me Know if this could be possible..!!! I want to connect twido suite 2.2 and Citect scada over local address of...
1,793
Hi, I'm student and for my degree I must to create project which will control one plant. I have twido plc TWDLAE40DRF and citect scada v6.0. I use...
38
12,393
Hello, i'm wondering if there is a posibility to set the schedule block in a Twido PLC with RTC from Vijeo Citect. Something like an operator...
3,104
Hello, I am trying to connect my vijeo citect project with twido but i cant do. I have been trying for a week :S Is there anybody who made this...
15,663
