CitectScada - Supergenies vs cicodefunction problem
sondreni
Feb 2014
Larvik
Hi there.
First of all I'm kinda new to CitectScada.
I'm trying to make a supergenie to call a cicode function.
Was hoping to use the same supergenie and genie to multiple motors. I have made one cicode start function for each motor. and was planning on entering this function in the metadata for the genie, And refer to it in at the startbutton in the supergenie.
I tried entering the startfunction directly in to the start button in the supergenie, just to test it. and it works perfect.
But when i enter it in the Metadata in the Genie, nothing happens.
Genie Metadata: %MotorStart%
function entered: MDO_P1_START
Super genie start button: ?MotorStart? , also tried TaskCall(?MotorStart?,"")
Did i manage to explain my problem? :p anyone tried this before?
just for the record. The connection between the Genie and SuperGenie works fine. tried with a normal variable tag instead of a function,
Hello everyone! I have a question about the allowable syntax for an expression in CitectSCADA. If I wanted an advanced alarm to trigger based on...
948
Hello, Just wondering if it is possible to make internal CitectSCADA project tags available to an OPC server. (Schneider OFS). There are...
929
Hello, This may not be the place for this but im curious of anyone has worked with CitectSCADA 2018 and windows sessions. Any feedback would be...
1,594
Hi Guys, I am still trying to learn citectscada and curious about the how the hmi stores the alarms (active, historical, etc). I could see a...
1,264
I want to make an application in C# .Net to read Tags from CitectScada (Local variables, Variables tags, Digital Alarms ...) so that I can process...
1,608
