cjim nc113 position control card
ateall217
Nov 2013
hale michigan
19
I'm trying to write a program using the latest CX programmer. I have the servo moving fine in the cw direction but in order to move it in the ccw direction im assuming I need to send a negative move to D20040 but MOVL will not let me use a negative # I'm trying to move &-262144.
Thank,
Welcome to the forum.
There may be multiple issues.
Have you reviewed the manual (W397) for the NC113?
The NC modules can be set up for relative or absolute moves.
Position data to the module must be in hexadecimal format.
The input type on the servo must also match how the NC113 is outputting the pulse train, CW / CCW or Pulse and Direction.
Hope this will help.
The servo is using Forward/reverse rotation pulse train positive So I would need to select pulse/direction output on the positioning card? I have reviewed the manual but wanted to know how to make a move in the opposite direction if I wanted to use a relative move. The manual is kind of confusing but from what I gathered it had to be in hexadecimal but movl would not let me enter -262144 in hexadecimal. it will let me move -262144. Does that mean -262144 coverts or I do not need to convert to hexadecimal when moving a - number.?
The module output must be set for CW/CCW.
Do not confuse yourself, forget about hexadecimals.
Use signed decimal values in the program, and do monitor in signed decimals.
No need to convert anything,- the internal format is binary anyways.
I have a cj1m cpu11 etn plc and wish to conect it to a network using ethernet. I am new to networking i have only used plc's for control to this...
3,696
Good day, I am having a problem with outputting pulse to the HIWIN servo driver using the OMRON NC113 module. The NC113 module is already...
3,745
I send the search for origin command and the servo moves faster then what I set it for,moves in the wrong direction and it doesn't stop when it...
1,826
3,454
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
156
