CLARIFICATION IN Tagname.UpdateCount
I have not used this personally but here is what the 9.5 users guide has to say about it.
.UpdateCount Read-only interger tagname dotfield that is​
incremented when a retrieval is complete for
the trend.​
Sorry it is not a lot of help.​
Hello all, Can someone knowledge check me to see if I have the correct understanding about FactoryTalk View apps Network Distributed - Many...
2,092
Hi All, I am looking over some Ladder Logic, and struggling to understand it fully. I know essentially WHAT it does, but not HOW it works. Here's...
4,018
Hello, I am having issues getting my channel output voltages to change (1-5vdc) by manipulating the data file values. I am also curious as to my...
1,881
I can't remember where I heard that if a block of fuses/terminal blocks that are all the same node (Voltage, Neutral, Common, or Ground) the...
3,470
My Pump Station Load is listed below and the Main Utility Transformer Supplying this load is 150KVA. From adding up all the current draw. The Pump...
2,860
