Class 1 Div 1 Hydraulic Fitting
ndzied1
Aug 2002
Chicago, Illinois
2,857
Hi There,
We have a hydraulic power unit we are building for a Class 1 Div 1 application. The customer wanted a specific kind of proportional relief valve that we not find with the proper rating so the project guys decided to put it in an expolosion proof box.
There is no problem getting the electrical connections to the box as there are conduit fittings rated for this but my question come in as how to get the hydraulic lines in and out of the box. Obviously we need to thread them into the box but in the NEC the code is pretty clear that in Class 1 Div 1 the fittings have to be approved for that rating.
They hydraulic guy is arguing that the code only applies to electrical fittings but my thought is that whatever gasses are trying to sneak around a fitting don't care whether it is electrical or hydraulic. :)
Has any one done somthing like this before? Are there Class 1 Div 1 hydraulic bulkhead fittings available? Are we crazy to put a hydraulic valve in a box? Do we need some sort of shutdown switch if the pressure in the box gets too great (probably not a good idea to blow a relief to atmosphere I'm guessing).
Thanks,
I'm looking for some clarification if anyone here is familiar with UL698a panels. Panel is out of zone/class'd area. with thermocouples extending...
127
Hi - I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing...
991
Can someone please recommend a signal light tower that can be used in a Class 1 Div 2 Classified area? Explosive gasses can be present under...
1,760
Hi everyone, I have a customer looking for a printer that has Class 1 Division 2 rating. I would like it to have a Ethernet connection and be...
1,188
Are there any code experts out there that can point me to a reference to support not using a Solenoid DIN connector with a LED in a Class 2 Div 2...
1,611
