Click PLC import
JeffKiper
Jun 2006
Indiana
2,460
Is there a way to import ladder files into a CLICK PLC? I'm usually an AB guy so I do a lot of Excel coding to create logic and import the logic. I can't find a way to do the same with a CLICK.
Back when I worked with Clicks all the time, I hunted down some of the AD Devs on linkedin and asked for some features along the same lines.
There response was "That's nice..." Ironically some of the other features I asked for ended up in DoMore and Productivity but a big Fat Zero were ever added to Click.
I believe they view click on Feature complete other than hardware changes. They want you to buy the more expensive PLCs if you want more features.
Click is totally intended as a basic starter PLC....
I bought 200ish of them last year and plan on buying another 300 next month, we are now going to use the Click Plus... for the cost and what you get they cant be beat, I have built another business around the CLICK PLC and doubt I could of done it using another.
They just added quite a bit to the clicks with the click plus line. For what they cost, they work okay especially if you need a PLC that supports MQTT with built in wifi. A brx or P1K is much more capable for not much extra but if it's hundreds of units, that little bit extra adds up.
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,089
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
223
Hi guys, i have never had to do a PWM Output or input before i have a Device that to dimm the lamp output from the ballast, the ballast has a 24V...
1,058
I am trying to set a bit to command the Zebra ZT230 to print a label and receive a confirmation bit from the unit via an Automation Direct Click...
672
Hi All, I have a click plc the I need to bit strip and 16Bit int. This is to get the alarms from these bits in the int. Do anyone know how to bit...
511
