Click PLC Output is a voltage divider???
Sprayman
Jan 2020
Chicago
50
Hi there,
Interesting problem today. Been fiddling around with a Click PLC. I have an extension module for it. A combo discrete 8/8. I am trying to drive an LED with it. Problem is. It seems that I can only get 5V from the output.
First off the pin out simplified is
V+
Y1
Com
Wiring is V+ to Com and y1 ties into that line.
Here is what gives me 5V:
V+ : no connection
Y1 to LED
Com to ground.
With this setup i have a voltage drop of 4-5 volts across the led. and a drop of 19 v between Y1 and ground. I am very confused.
Note, if I use V+ to ground. The led stays on regardless of output state. Likewise, if i tie V+ to 24v. The led stays off regardless (also eliminates the voltage division.
My led is tied to +24V, so I need to tie the output to ground when it goes high.
More detailed pin layout
https://cdn.automationdirect.com/static/specs/c016cdd2.pdf
That is a sourcing output module. You need to connect:
24VDC+ connect to V+
24VDC- connect to C2
Y1 will send out (source) 24VDC when energized.
If you need a sinking output module, you have the wrong module.
Hi guys, i have never had to do a PWM Output or input before i have a Device that to dimm the lamp output from the ballast, the ballast has a 24V...
1,121
I purchased a Click C0-02DD1-D plc because i was interested in learning about plcs. The model i purchased has sinking outputs and only 4 input, 4...
1,030
I have a click plc c0-01dd-1d, I am not getting any output voltage from y1. I wrote a simple program to work with my c-more panel. On my panel I...
1,529
Click Plc/analog 0-10 v output module/0-10v dimmable led driver. I made a program using multiple drum to create by increment fade in and out led...
1,424
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,138
