Click plc
Icekold
Sep 2012
Indiana
I have been writing a program using CLICK hardware. I used an OUT oneshot to reset coils, such as C1900-C1928. They all rest but one. When the the instruction is executed the coils will not reset...only with this one instruction of 28.
Has anyone ever heard of this ?
Note that you're posting in the Practice forum, so your message may not be getting seen.
I do some Click programming and might be able to help. Could you post your program file?
"OUT oneshot to reset coils" is a strange way of doing this. Why not use Reset (RST)? To find your coil which has a conflict, use either Find (Ctrl+F), or Menu>Program>CrossReferenceView.
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,111
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
244
Hi guys, i have never had to do a PWM Output or input before i have a Device that to dimm the lamp output from the ballast, the ballast has a 24V...
1,092
I am trying to set a bit to command the Zebra ZT230 to print a label and receive a confirmation bit from the unit via an Automation Direct Click...
682
Hi All, I have a click plc the I need to bit strip and 16Bit int. This is to get the alarms from these bits in the int. Do anyone know how to bit...
517
