Codesys/Modbus/IFM CR1074 display questions
JasonO
Nov 2020
Indiana
Hello,
I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little explanation of the project:
What we're doing is controlling a portable rollformer for roofing metal, so we want a PLC with a 7" HMI. The specific requirement from the customer is that they do not want touchscreen operation - all navigation and entry on the screen needs to be via buttons/function keys/membrane keypad/something like that... It seems to be extremely difficult to find an HMI that will work, especially because it also needs to function down to -10 degrees C, and hopefully be readable outdoors. The machines get mounted in enclosed trailers, and the screen is just inside the trailer door, so that the operator can just open the trailer door to use the machine (see attached pic). So the screen needs to be more or less rated for outdoor use.
So, I finally found the IFM CR1074. It seems like this should check all the boxes. I haven't ordered one to try yet; I'm mostly exploring Codesys at this point.
What I'll want to do is use the CR1074 as just an HMI, and have it communicate with a Do-More BRX PLC via Modbus (or maybe Ethernet/IP?). What I'm not sure of is how to set this all up, and how/if it'll work. On the PLC side I'll have roughly 50 bits and 50 Dword variables that I'll map into the Modbus memory blocks. That's all easy and I've done it before. But then in Codesys I'll need to set up the Modbus addresses, and I expect I'll have to convert the registers to the 32 bit integers as needed. Some of these variables will be available to edit on screen (ie. the operator will type in quantity of parts to cut and target length, using a USB numeric keypad plugged into the CR1974). Those edited variables will need to be written back to the PLC.
On a "normal" HMI the data conversion and Modbus writes (ie after entering data into a numeric field) are taken care of and I don't have to mess with any of that. But I'm not sure how that all works in Codesys, and am not finding much information online. Should the CR1074 be the Modbus slave, or Master? How do I set it up, so that it'll display values read from the PLC, and I can type in a new value that gets written back to the PLC?
Any insight would be appreciated!
IMO this will be easier if you just write the PLC program in Codesys, utilizing the HMI's runtime and then use something else as your remote IO. The process then becomes very easy.
If you already have too much written in the BRX and no interest in writing it in Codesys, the Modbus data comes into the Codesys device the same as any other. You'll have the freedom to perform any sort of logic/manipulation on it that you wish within the Codesys environment. There is a lot of useful information on the web for Codesys, a few keywords should get you going. Search YouTube for Tohid Alizadeh, or Jakob Sagatowski as well as Codesys themselves (their help files can be a bit brief though).
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,855
I have a program for a PLC, but I don't have the PLC now. I am running the PLC program in the Codesys simulation mode. Can I connect SCADA to...
1,734
I'm going to be adding Modbus TCP communications to a Turck Codesys system. There will be more than one HMI hitting the Turck hardware, hopefully...
1,042
Hi all, A couple of years ago, I ran some tests with MODBUS TCP communication between rPi running CodeSYS and a couple of Arduino's. I remember...
3,064
Codesys V2.3.9.49 (Build NoV 17, 2015) WAGO 750-881 Controller WAGO 750-652 RS232/485 Serial Interface Beka BA488C Serial Text Display PLC_PRG in...
2,374
