Cognex FTP setup
Was anyone able to come up with a solution? In my log files I see USER admin 331 and PASS *** 530. I cannot find where the password is set?
Here are what those reply codes mean:
331 Username okay, need password
530 Not logged in.
So the 331 was returned when the FTP server received a valid username, but then the password was not accepted.
You might try the anonymous user (anonymous or just ftp), then use me@ as the password; some FTP servers are set up like that, but require,
as a courtesy, an email address as the password; the hostname portion of the email address is not needed as the server already knows the host from which the connection is coming. Of course, that will no longer be the email host, but that was the convention several decades ago.
thank you! That helped but I'm still not seeing any images being saved? The IIS log file looks like it is trying to STOR a .bmp file in the location I've directed it to but there is no image?
Does my IIS Physical Path I specify for the new FTP Server I created need to have the same path I specify in WriteImageFTP command in In-Sight? The original post was using the file name Bad, instead I'm using a specific file path such as C:\L68_Compression
Where does your ftp point? If it's already in the directory you want, don't add folders to the name path.
For my username I had to include the PC name.
PCName\User
Just wanted to see if anyone else is using this functionality, and if so how fast they are able to execute this command consecutively? I was...
2,326
I need to load jobs to an Insight camera via FTP. I would like to automate this somewhat. I am thinking about making a batch file that would log...
2,259
We finally replaced our Cognex Checker with an IV-3 and I'm wondering if can replace the s/w in the monitor with anything else. I haven't been...
104
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
135
Which signals do I have to use to get data from camera. For example camera detects a defect and sends signal to controller. Power cable: CCB-PWRIO-05
220
