collecting data plc5
roy357
Dec 2008
El paso TX
hi all,
I need some advice, I have a plc5/20 in a 16 rack in a leak detector chamber(There are 8 chambers aprox in this area each chamber has its own procesor). what I want to do is: on every part accepted the leak rate is stored in the processor, and i need to be able to print or save this values every single test. I can't install a printer on every chamber in the plant. Is there a method to collect this data and then print it on the office??
any idea???:D
roy
Roy,
An easy way to do this would be with a Red Lion DataStation Plus product to log the data and store it as a .csv file. You can then access this data from anywhere in the plant via the WebServer and simply open the datalog file using Excel and print it out. This would be very easy to do in Crimson.
Thanks,
Joe_WaZoo
I have been able to get trend data through RSLogix 5000 when we are running the program and we are online, but I'm not sure how to collect data...
2,120
Hello Everyone, I work for a company who builds a machine for the automotive industry. Recently, we build a new line at the plant but the line...
4,166
Hi, I have a few Siemens S7-1200 PLC's with TP700 Comfort HMI's (each PLC has it's own HMI). These PLC's just count products, and the amount made...
2,461
Hi Guys, I have a 2x Omron FQ cameras with a Touch finder panel, inspecting eye drop bottles on high speed conveyor interfacing with Siemens S7...
4,376
Guys can someone help how we can collect the data from a press for press loads and dump them into an excell sheet for analyzing
1,894
