Com Profibus IO Configuration
juice76
Feb 2006
Southeast
44
I'm attempting to use the ET200S IO for the first time. The DP master will be a 555-1105. The DP Slave is an IM151-1. I need to use 120 volt AC discretes. When I configure my IM151 with the 6ES71314EB000AB0 2DI and with the 6ES7132HB010AB0 2DO modules, the Identifier field shows them as 8DO and 8DO. When I export the binary file, and then merge it into my 505 software, the modules show up as 8 inputs and 8 outputs. They should be showing up as 2 ins and 2 outs.
Any help is appreciated!
Juice76,
I had a similar 'problem' when I configured an ET200S (IM151) to work with an S5 115U, profibus master IM308C, I used 4 DI and 4 DO modules in the IM151 and I know that a byte was allocated to each module, so I effectively lost 4 bits per card in the IM151 rack, I could only use the first four bits (I0.0 to I0.3 for example), that might be the case for you as well, but you loose 6 bits per card.
Paul
Thanks Paul. According to Siemens Tech Support that is the case. I just wanted to hear from someone else because the tech support guy I was talking to kept laying the phone down, and asking someone in the background. I didn't have a lot of confidence in what he was telling me.
I suppose it's better he (tech support) does ask someone who does know than just guess at an answer to give you. :confused:
This forum is the only tech suppport I use!
Paul
Hi Juice
I'm digging back in my memory to the last time I used TI, but don't you have the option to 'combine' I/O addresses or something like this? So you can have a virtual module in the I/O config which consists of both DI and DO?
Anyway, I don't think losing a couple of bits in a 555 should cause too much pain - again I seem to remember you have an enormous address space in that CPU?
Ken
If I remember correctly, for the TI505 PLC's the I/O foot print per module in a Profibus slave is bounded by the original 505 module I/O count steps such as 8, 16, 32. I had encountered this same thing in the past when using a ET200L-SC, and the Smart Connect hardware was much like what the ET200S came out to be.
As far as I/O available, with a 555 you have 8192 I/O points addressable through the I/O image register, and these 8K of points can be word or discrete. As if that's not enough I/O, the CTI Profibus card maps into V-memory; so you have a number greater than 8192 possible.
Tom
Hi all, I have a blown film line with a Siemens 555 plc, 26 profibus slaves and 2 devices conected on the MPI network. I have Com Profibus...
3,010
Hi My devices are as follows: S7-300 > CPU 315-2DP (6ES7 315-3Fx-0AB0) PROFIBUS CP342-5 (3425DA02-0XE0) ASi CP343-2...
4,982
I'm looking at an old Profibus configuration on ComPB 5.1 and upon loading the .et2 file I get an error Upon loading an old configuration et2...
1,995
Dear All, How can i go online using Com Profibus V5.1 Which particular cable do i need? and what is the Procedures to go online? When i try to go...
4,646
Hello, I have a problem, right now i have a empty memorycard for the IM308C and it isn't possible to program it via the profibus port on the...
1,665
