Combining two words %MW into double word %MD
IODevice
Jun 2014
Sarajevo
1. Is there a way to send %MD from Twido to Vijeo Citect 7.20? For example in Twido %MD100 reads %MW100 and %MW101 combined.
2. If there is no way, how can I combine two %MW into one %MD in Vijeo Citect 7.20?
1. use directly %MD word address, this is easiest (one %MD address uses to %MW addresses)
If you want combine two different words (%MW) then you can example move these word values first to two different double word addresses (indirectly) and then you can count them together on double word side on plc program.
(example. you have two word, something like %MW0 and %MW10, you can now see same values on double word addresses %MD0 and %MD10 => add/subtrat/multiple these double word together to some double word address, ex. %MD20. Just remember that you can't use now %MW1 and %MW11 and %MW21 words on program, because double word addressing uses them.
(Another way is to convert words to real and them to double integers on twido, but there will be rounding issues with this method)
2. On vijeo read %MW20 address, but use format long for variable. Long means same as double integer on Vijeo. You should see same value than what is on twido's address %MD20.
I have a IDEC Micro Smart PLC, I need to take day date Integer and Combine it with the hour integer Example if the day date integer read 00012 and...
2,469
Hi, I have a functions which extends codes generation for RFID tags. Basically it takes a char and splits it's hex value over 2 chars. I cannot...
24
9,534
I'm onsite right now and I'm trying to decide how to proceed. I need to make some major edits to the Micrologix 1400 file, but the guy with the...
1,172
Hello, I am trying to write a logic to control a pump. I have my logic as attached. Is there a way to do Auto and Manual control without having...
2,743
Hi there, Quick Question. I have 2 PLCs and 2 solenoids. I would like to wire these up so that If either one turns on, it will turn on both...
17
11,478
