Comm cable between PanelView and PC
ayman metwally
Dec 2003
Cairo
258
Good evening/morning,
One of my customers wants to purchase the communication cable between a PanelView 500 (DH485) and a PC, He asked me to support hem.
I'm not that AB guy, but I went to AB websie at THIS LINK
And I ended up with these results, To interface with the PanelView 500 using:-
1- To interface the PC's USB:
1747-UIC (USB to DH-485 Interface Converter)
2- To interface the PC's RS232:
1747-PIC (interface between a DH-485 and RS-232, Powered through a DH-485 device)
So can you please give me the OK about these results?
Another thing: I can see that these 2 modules are "converters" not cables, So do I need extra cable or am I missing something?
Thanks in advance
Do you mean a Panelview 550?
Those are the correct cables. You may need to add a 24V power supply for the DH485. AB sells it, I don't have the part # in front of me.
You are also correct that they are converters. DH485 is based on the rs485 standard. Your PC is either USB or RS-232. DH485 also includes a 24VDC pair, which is sometimes used to power the converter.
If you go the 1747-UIC route, you will also need a 1747-C13 cable as well. Also, find out if the PV550 is DH-485 with a true DH-485 connection, or if it is DH-485 with an RS-232 (9-pin d-shell) conection. If it has the DH-485 connection, you will need either the PIC or the UIC; if it is an RS-232 connection, you will need the 1747-CP3 (null-moden) cable. The DH-485 connector models will have a P/N of 2711-x5A2 or -x5A3; the RS-232 connector models will be 2711-x5A5 or -x5A9. If the PV550 is connected to a SLC already, you won't need the 1747-NP1 power supply as the DH-485 link will be drawing its 24 vdc power from the SLC com port.
Hey all, I need to know which comm. cable will be needed at run time between PanelView Component C400 (2711C-T4T) to Micrologix 1200 ?? The PV...
2,011
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
155
I was trying to connect a HMI (EZTouch Panel) to SLC500. The HMI had a PLC port (RS232/RS/422/485) 15 pin D-female connector. The PLC had a RJ45...
2,750
I am trying to connect to a G.E. sy/max plc, the software runs on dos and it is version 2.03. I have a picture of the cable it has NRD on one end...
1,555
I have a PV600 (2711-T6C16L1) Ser B, Rev C, FRN 4.43 . I successfully downloaded a PV program to it using a 2711-NC13 cable. However, that...
18
3,662
