nievesdelimon
I'm working on a turntable which has had Valve blocks, master blocks, and IO blocks replaced with new ones. We're using BNI008M ofr MB and BNI0090 for the IO blocks. I configured one side first and it was working properly, communicating, the tooling worked fine in manual mode. Then I moved onto the other side and nothing worked, comms were not ok, the MB was not getting any inputs according to the PLC. I switched the MBs to verify if one wasn't working, however, after switching them nothing worked on any side anymore, afterwards I switched them back and comms are not ok on both sides, nothing works anymore. Does anyone have any Ideas as to what is happening or what might be causing it?
