Communicating Siemens S7300, S7400
micromax
May 2003
india
I would like to communicate with Simens S7300, S7400 using Visual Basic. I want to know any other possiblity except OPC to communicate the same.
There is Prodave MPI from Siemens. This is a dll type library, I don't know if it will work with VB.
B-plus makes an activeX library for € 2500.
Deltalogic makes ACCON AG-Link S7. This is a dll type library, stated to work with VB.
MHJ software makes an MPI driver dll library, stated to work with VB.
this should give you something to get started with ;)
Here is a "Native" TCP connection and the source for VB that will allow you to communicate to a CP343-1 or CP443-1 ethernet processor. It works quite well. I use it for demos and it will work over the internet. It's a free-be, knock yourself out.
Good morning, I am trying to find the best and most cost efficient way to send data from a siemens s7-300 to a pc through a serial port card...
1,721
Dear All, May I know if anybody here has a set-up like this? A siemens CPU315-2DP communicating with Siemens BW500 Belt weigher integrator over...
2,361
I have a Festo CPU model HC20-60-FST that has an Asi master card plugged into the backplane as well as an 10MB/sec Ethernet Controller P/N...
2,858
Hi. I'm using Protool v6.0 and am trying to communicate with some Seimens TP170A Touch Panels. (Download some language changes for the displays)...
3,293
