communicating with riveting machine
LewisII
Aug 2005
Mexico
I want to communicate from mi plc logix1500\panelview550 to riveting machine(BALTEC).
Baltec has two ports (485\232) the first one is busy and the other one is able to use. I Dont know if I can use the 232 port for my project or if is necesary to use the 485 port, also I dont Know if this ports have driver comunicatios for my PLC\Pview.
Anybody here could help to me to acces Baltec Data.
I have two programs in the Baltec Machine, but actually we select the program from the baltec control panel. The goal is to select\change the program form Panel View and Display data and results of the Baltec sequence.
If you have a LRP series ML1500 (giving you two serial ports), you can set one of the ports to ASCII in the Channel configuration. Then use the AWT or AWA instructions to send data to your serial device. Hope that helps.
thanks for your reply Jstolaruk, Do you Know where can I find more data or manuals about configuration Baltec comunications.
thanks
Dear All Please help me about Below picture problem.PLC not communicating proper.
185
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
701
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
462
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
366
Have a customer that has a running 1756-l83es, communicating to redundant ABCIP IO servers for Wonderware 2020. This configuration has been...
887
