Communication issues between PV+ 1000 & Laptop
ARJeza
Aug 2013
india
We got a PV+ 1000 (2711P-K10C6D1 A C) communicating to SLC 5/03 over DH485 through a 1747-AIC coupler without any issues and i can communicate to SLC 5/03 through laptop over DF1 serial port.
However i can't establish commuication between PV+ 1000 and Laptop neither over it's serial port or ethernet port.
I setup IP on PV+ and laptop and ping it successfully but can't see the PV+ on rslinx RSWho.
I also tried on serial port without any success.
Pls advise,
thanks,
ARJeza
welcome to the site
What is the I/P address and Subnet Mask settings of the HMI and the Notebook?
Also are you using a hub
is the E/net cable straight thru or a crossover type
Thanks iant,
I am using a straight ethernet cable with crossover adapter connected directly to the Pv+ 1000 no hub/switch in between.
I tried with straight serial cable with gender changer too.
The PC is ethernet is set up 192.168.0.5 & PV+ with 192.168.0.31 and mask 255.255.255.0.
I got a spare PV+ 1000 Touch, i could communicate with it with another HMI application. I loaded the application file from PV+ 1000 ( keypad) to this working setup of PV+ 1000 Touch, and same comms problem replicated here.
Pls advise.
ARJeza
I had a thought that the PV+ subnet default is 255.255.0.0
check the firmware version of the screen
Hi iant,
The firmware version is 5.10.00.09 (CPR 9 SR2).
I have tried with subnet mask of 255.255.0.0...no success.
I was wondering why when i load this application on a spare PV+1000 with Touch, there too i have same problem...where as other application on that spare work just fine.
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
171
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,474
PLC L30ER V30.01 VFD PF 525 V7.0001 Running into an issue that I've never seen before. Ive configured many PF525's before so i know the...
1,236
Hi all, I have been having a frustrating time communicating between my esmart04 HMI and my Productivity P1-540 PLC. Currently, I am simply just...
1,882
Hi All, At site, there is a Pro-Face 19” screen Model: SP-5800WP FWXGA complete with PFXSP5B10 box. Connected via Ethernet to the screen...
3,172
