Communication of Micrologix 1200 with Wonderware on ethernet
manasi
May 2007
maharashtra
123
Dear All
Please let me know the procedure of communication betwenn micrologix 1200 and wonderware on ethernet (TCP/IP). Which driver i need to install
Regards,
Manasi
I believe you can use the DASABTCP driver that is provided on the I/O servers CD. Selecting SLC500_TCPIP object should work.
Actually I am having total 3 nodes on ethernet . out of 3 nodes two are SLC5/5 and 3rd is micrologix 1200. using ABTCP ( AB ethernet direct) i can communicate with SLC-5/5, but i cant communicate with micrologix.
can you please explore the steps i need to carry out for micrologix 1200 communication.
-Manasi
It looks like I should have steered you toward the DASABCIP driver instead. It has options for SLC 5/05 (SLC500_EN object) and Micro with ENI (ML_EN object). Make sure you uncheck the selection that says must be enabled for Micro 1100.
I found these options within the latest version 4 of DASABCIP. This is also included on your I/O servers CD.
I've never personally used these so let us know how you come out.
I don't have any prior experience with MicroLogix so the Communication Toggle Button is new to me. We currently have a few MicroLogix that are...
2,243
Hi all I have micro logix 1200 and automation direct panel (EA9-T6CL). I have downloaded .RSS file in micrologix 1200 using 1761-CBL-PM02...
1,811
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,639
Hello All, We have a MicroLogix 1200 series controller on a package in our plant. We need to connect a serial device to MicroLogix 1200 for...
4,653
Good Day All, I've a MicroLogix 1200 and Panel View 300 Micro installed on a package in process and its working fine. PV is connected with 8 pin...
3,652
