communication problem after change hmi device in wincc flexible 2008 project
TIA Portal doesn't have this issue. I can add an S7 driver and Modbus driver on Ethernet, and it's fine.[/QUOTE]
can I open my original project after conversion to flexible 2008 sp3 with tia portal ???
is it nessecary to use latest version of tia portal v16 ??? as my laptop is weak can I use tia portal v14 or v15 ????
all I need open the project with suitable software and change the hmi device to pc runtime of my project with no error is this possible ???
I can not build the project from the start with wincc advance or tia portal I am biginner in programing !!!!
Yes.
No, and yes.
Yes... it may be possible you have to make some adjustments.
Yes.
No, and yes.
To expand on this: there are often errors when you compile the first time in TIA Portal, because some things that used to be warnings are now errors, and there are new things it checks for during compilation that previously would have just quietly not worked.
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
197
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
204
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,634
I am having PLC S7 200 smart model- ST 30 . In which I am getting problem in modbus communication of PLC and VFD via built in RS 485 port of PLC...
808
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,343
