communication
What is the difference between English, French and German? What's the difference between telephone and telegraphy? The first use a different set of words to express what has to be said. The latter use different signals to communicate. It's the same with ethernet, DH+, RS-232 and DH-485.
You can find more on RS 232 here.
DH485 and DH+ are both protocols used by Allen-Bradley. These are both based on RS485, of which you can find more info here. DH485 is limited to 19200baud, while DH+ only uses baudrates above this and limited to 57600baud.
More info on ethernet can be found here.
Kind regards,
THANKS Jean Pierre Vandecandelaere,
I HAVE ONE MORE QUESTION
WHAT WILL BE THE DATA TRANSFER RATE BETWEEN SCADA(PC) AND PLC?
IS IT DEPENDS ON PROCESSOR SPEED?
THANKS IN ADVANCE
MJK
Hello muralidharjk;
This will depend amongst other things on the processor speed, but also on the RAM memory available, on the %loading of the CPU, on the existence of a separate communictation processor, on the physical limitations of the protocol selected and the network data rate.
Amongst other things.
Regards,
Daniel Chartier
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
34
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
93
119
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
146
Hello We have installed several G.E. Fanuc 90 70 PLC Everything was ok but suddenly we can not communicate anymore with any PLC with the software...
77
