Compact Flash Card
I would not bother with those high-performance, expensive CompactFlash cards.
Try to find an ordinary PCMCIA Type II ATA Flash card, or an ordinary CompactFlash card of under 2GB in size, plus a Type II PCMCIA Adapter.
Your PanelView 550 terminal must be Version 3.x or later firmware to support ATA Flash. If it is very old (v1, v2 firmware) you should use the network connection to download to it.
Thanks, I appreciate your comment, but are those cards ok? I´ll rather go with the sure stuff, because I´ve heard that some of the non AB cards dont work.
This is one of the few instances where I don't think the A-B labeled cards are a benefit.
PanelView Standard terminals don't do any repetitive writing or logging to the CompactFlash card, and are in my experience very widely compatible with consumer-grade CompactFlash ATA memory cards of under 2 GB in size, formatted in FAT16 format.
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
121
Evidently I'm not straight with this... If you do an program edit, and do not re-save the file to the flash card, when do you risk booting up the...
1,848
dear all, how to upload/download program from/to 1784-cf128 compact flash card to/from CPU
2,033
please help me I don't know lock password for memory card CF of B&R or compact flash card CF of B&R how is lock password for compact flash card...
1,685
Hey guys, I'm hoping Ken can help me out again. I have seearched numerous pages but cannot find a definitive answer. As I am sure your are...
3,908
