compact logix 1769 L30E contoller
We're gonna need a lot more context than that.
New or existing PLC?
What physical connection do you have between PC and PLC?
What software are you trying to use to connect?
What makes you say you can't connect?
Have you googled the manual and read about what the status indicators mean, including a solid red OK light?
Hello
Got a red solid OK light and I can't get connect to the controller.
Any help!
As mention by ASF, more info is needed.
Also if you don't already have a SD in your slot, put one in and cycle the power, the fault dump will write to the card, it will be useful.
Been seeing a high failure rate on these PLC's on 2 of our process. The control power is feed through a APC UPS to a 24VDC power supply to power...
4,081
Hello. I am trying to figure out how to setup a PID in Control Logix 1769 Controller in a way that it would control a drive speed by sending...
1,652
Hello guys, I need to add in a few discrete and analog cards for an existing 1769 Compact Logix system at a local Treatment Plant for an...
3,737
Hello Everyone, First of all, I would like to thank you for everyone who helped me in the previous post and this platform is really helpful for...
3,223
I am using ab 1769-l30er for redundancy logic, the secondary controller is not being recognized, the icon is replaced by a yellow question mark...
1,978
