Compact Logix / Panelview - Tag Names
Sep 2003
Philadelphia
75
Can anyone point me to an example of a CompactLogix - Panelview program. This is my first attempt programming Panelview and/or CompactLogix. This whole "Tag Name" concept is new to me and I'm getting hit with a double whammy.
I was able to copy the sample program in the Panelview QuickStart manual using my Panelview 900 (2711 T9A5) and a SLC 5/04. I just typed exactly what I read; can't say I learned much.
I can't find a similar tutorial for the Panelview and the CompactLogix. I would be happy with a simple basic example. Something like 0ne button on the Panelview. Press the button and see a bit change in the CompactLogix. When a bit changes in CompactLogix see a change on the Panelview.
As I mentioned earlier I have a 2711-T9A5 (RS232-DH485) and a CompactLogix 5330. I'm using RSLogix 5000 v.11, although I have access to different versions.
I'm a newbie with AB PLCs in general, but thanks to this forum, I can get by. It was here that I learned I needed a PIC 485 driver to connect to the panelview. I am able to program the 5330 enough to see inputs turn on outputs and some basic counter - timers rungs. What I'm really having difficulty with is the tag name / tag address concept, especially in the panelview.
Thank you for any help you can offer;
Frank
Where? I see many different *.ACD files in the Program Files folder under the sample folder but none seem to be associated with a panelview. Looking in the installation CD I can't find any ACD files.
Could you elaborate on where they are?
Frank
Does anyone know how to synchronise the time between these two? I had thought that the HMI could write a LINT (time/date in microsecronds) to the...
2,199
Has anyone ever used a 2711R -T7T Panelview 800 with a Compact Logix PLC over Ethernet comms? the 2711R -T7T Panelview 800 is usually programmed...
3,947
My plc is thr 5069- L306ER and my HMi is the Panelview plus 7. My customer wants me to log on the SD card the values of 8 tags of 2000 arrays. On...
1,414
Hello all. I have a question about communication between my HMI and processor. Somehow, one of our maintenance techs goofed up the program. We...
1,921
I'm wanting to use a password protected button on a Panelview plus 700 standard HMI to turn on a input on a compact logix controller. Is there a...
2,768
