Compact logix PLC with Modem to send SMS
Jason P
Jan 2006
Burlington
22
Hey there,
Does anyone know how hard or easy it is to send SMS text messages using the RS232 port on the PLC to a GSM Modem and roughly whats involved to do this?
Hi Jason,
It's a relatively painless process, and will vary from PLC to PLC.
In principle, you compile STRING data and use (in the case of Logix500) the AWT (Ascii WRITE) command to output directly to the modems serial port...
eg 'AT+CMGS=0123456789 <CR>' (mobile/cell number)
'Message Body' <Ctrl Z>' (sends text message)
I've posted a few examples over the years if you search...
I normally use (say) Hyperterminal to first prove the modem/baud rate etc, then just replicate using a PLC.
Hope this helps!
Rob
Is it possible to get the LED Status Lights out of the code? I will use the GSV Block with the 'Module' Class and 'LedStatus' for the CPU. I am...
589
Been seeing a high failure rate on these PLC's on 2 of our process. The control power is feed through a APC UPS to a 24VDC power supply to power...
4,038
Has anyone ever used a 2711R -T7T Panelview 800 with a Compact Logix PLC over Ethernet comms? the 2711R -T7T Panelview 800 is usually programmed...
3,951
Hi I'm currently doing a college course in robotics and automation and a question we were asked was. A software application used by production...
3,658
is there a way to open a compact logix plc program and then compare that to the program that is actually running in the plc Thanks
1,074
