CompactLogix L35E to 1769-OF8C ???
JHarbin
Sep 2009
NC
909
What am I doing wrong?
I have configured my module for PERCENT RANGE (0-10000) and have a tag connected to output 0. No matter what I set the tag to, it shows up at Local:2:O.Ch0Data but the 4-20mA stays at 4.0 mA.
I know it is something simple just can't figure out what.
Could you post your program for us? I don't know about everybody else, but my crystal ball is running a little foggy today ;)
There's a number of things it could be, from configuration, to the processor not being in RUN, to the program rung not scanning, to...
Yea - I know it could be about anything, but the processor is in Run and I am programming in function block and the routine is running. I'm reading my AI points right next to the logic for the Analog Output.
I just figured there was a gotcha that the old CompactLogix gurus had figured out long ago.
I finally figured it out - the Hi Clamp is set by default to 1. Since I wanted to use PCT RANGE I had to set it to 10000.
MODERATOR REQUEST:
If you have a new question, please create a new Thread for that question.
Go back one level in the Forum to the "LIVE PLC Questions & Answers" page, and use the Start a New Thread button.
If your question is directly related to an old question, you can link to the old question by copy/pasting the URL of the old thread into your new thread.
Welcome to the Forum, Andre !
When you create your new thread, please include details about which controller you are using (MicroLogix or CompactLogix), as well as details about the analog circuit connected to the module.
Hi, I am new to PLC and seeking advice here. We have a compactlogix 1769-L35E. The L35E has been situated in shelf for a while, therefore, the...
3,317
I have an issue with the communication trough the MSG instruction, I want to send information to a printer from a 1769-L35E, I have configured the...
17
16,182
Has anyone else seen or heard of this? I have about 27 connections but seems my message statements are hanging up at times. (usually around 45...
19
7,215
I was told by the user manual and by users that if you have a solid red fault light then the CPU is shot and it needs to be repaired I bought a...
4,924
CompactLogix 1769-L35E Processor unit. I HAVE A Compact logix processor that went dead on me for no particular reason on one of our equipment. I...
3,795
