CompactLogix L36ERM
tjntjntjn
May 2012
USA
94
Hi there,
Just a quick question. I have CompactLogix controller L36ERM that gives me energy storage fault. Controller is running fine. However, I don't see any battery on the side, so before I start taking it apart to get inside I'd like to ask if there is any battery inside that can be replaced?
There are multiple reasons why you are getting this fault.
There are Technotes in the knowledge base that may apply to your specific issue.
However, most of them have “Techconnect” access level and can’t be posted here. If you.have Techconnect then search for “Energy Storage Fault”
First, check to make sure there is no check box set under the minor fault tab.
Thanks.
Fortunately for me I do have TechConnect. However, the answer I found was not what I was looking for.
Usually this fault is seen when the ESM is missing or needs to be replaced. Only two options.
Or the checkbox is checked on the minor fault tab in Controller Properties, as contr_conn mentioned. The module is not removable or replaceable for CompactLogix.
Hi All, Fairly new to PLCs and in particular communications between processors. I'll explain the problem best as I can. I have a new water...
2,109
Hi guys, I have taken on a project to migrate a ML1500 project to a CompactLogix L36ERM. I have tried using the RSLogix Project Migrator and...
3,414
I have a new L36ERM PLC and the download is taking forever. I'm talking upwards of 3-4 minutes download, which normally takes ~10 seconds? All...
2,651
Hello all, I am doing a project where I need to use a 1769-L36ERM. I am developing offline as I am waiting for my hardware to arrive. I have a...
21
11,542
Hello Gents, I am currently using AB CompactLogix Processor L36 ERM (Mid Range Controller) in an application. One of the device on the network is...
5,543
