CompactLogixL43 with Kinetix 6000 on Sercos
Christoph
Sep 2003
Indiana
346
Trying to configure the 2nd drive on this machine. It is being
difficult. I have the gains speed encoder data all with good data. when I try to
run the tune function it says it can't complete the test, speed is too low.
I have it set to the max speed. Any Ideas. Also if I try to run it with
current data it faults on F19.
Did you mean E19? That is a following error, and would make sense with what you're seeing. Check the encoder. Also see if the motor is actually rotating or not.
Motor is not turning, it was running until we changed some data to correct an
incorrect position. It should work with the new settings I don't get the auto tune not working!
Just a thought, but do you have the controller in RUN mode when you execute the auto tune? There could possibly be other codes/commands interfering. Try it in PROG mode.
Only other thing to do is restore the changed data and figure out why your reading is incorrect.
It did work, but still no auto tune. But, I found the value on the conversion tab was wrong. Once changed everything started working!
Dear All , I need help about my compactlogix L43 IO LED blinking issue . when power goes off after when we tried it to ON only CPU will powered...
1,542
Hey Guys, I have a CompactLogix L43 system. The first 1769-PA4 Power Supply has 6 Digital I/O modules, mounted to the CompactLogix and the next 4...
1,555
Hi guys, I have the first Kinetix 5100 in my facilities. I already configure the movement in Speed Mode, I am sending the Analog signal from my...
22
Hi all, I am upgrading a couple of 2094-BC01-M01 servos with 2198-H015-ERS. The original code uses MSG instructions to control (release, engage...
63
Hello all I was trying to autotune a Kinetix 5100, I got an encoder fault and it says to check the wiring. I remove the 24 volts from drive to...
49
